Multifunction DAQ
Outputting a 12-bit binary to a DAC using a DAQPad 6509
Hi All,
Please bear with my inexperience with LabView. I am currently using LabView 8.5.
I have somewhat of a multilevel problem, one that I have no idea how to even begin tackling.
I am trying to make a VI which will take 12 separate output lines from a DAQPad 6509, and I would like to sequentially convert these into binary code. I then need this binary code to be inputted into a single-input 10-bit DAC (with the last two bits written as 00). However, when I input the binary, it needs to be done with the chip select set at "low" (meaning, within the same VI, I want to have this binary generation and transmission start when I set the control for the DAC to low). Finally, also within the same VI, I want to include a reference clock with which I can tell the DAC when to begin / finish reading each bit. In essence, I need 3 separate outputs (one for main start, one for timing, and one for the binary generation). Can anybody recommend me a sample VI that can help me in meeting these requirements?
If 12 separate outputs is too demanding / unfeasable, I might be able also to do this with one single output line, bit I need to ensure that the timing between bits is syncronized between the two.
Thank you for all of your help and time!
David
(2,854 Views)
(2,847 Views)
