Multifunction DAQ
Output signal is not generated in proper shape & frequency from analog output (PCI 6251) as it is generated in labview
I am using PCI 6251 hardware for my application to control a converter in close loop ( Hardware in loop). For that I sense voltage, curret and trangular wave through analog input. Depending upon the input my control algorithem generate some control signal. This control signal is compair with input trangular wave to generate the pulses for DC-DC converter.
My maximum sinal frequency is 5 KHz.
But proble is that I am not getting the signal in proper shape and frequency as it is generated in labview.
I attached my model for your information. Could any person help me out from this problem...
I am not able decide my number of sample and loop timing.
Message 1 of 1
(2,925 Views)
