Multifunction DAQ
Not able to create task in NI max although the DAQ is detected
I am trying to read signal from NI9202 DAQ but when I create the task I get an error which I have attached below.
LabVIEW version:17.0.01
NI Max:17.5
DAQmx: 17.6
The DAQmx drivers installed at the start were 17.5 but then I figured out that in order to run NI9202 I need to upgrade the driver to 17.6. When I had 17.5 driver I got an error saying 'Unsupported Hardware'. But when I installed the 17.6 driver I was able to see the NI9202 DAQ name.
One solution I tried was to remove the DAQmx driver and install it again, after installation gave out the same error.
Second solution I attempted was to uninstall and reinstall everything including all packages still gives out the same error.
I need help.
Thank you.
(1,218 Views)
Can anyone help me with this?
(1,156 Views)
