Multifunction DAQ
No data acquired from a single-ended sensor
Now I have trouble with connecting a HIH-4000 relative humidity sensor to my NI DAQ equipment (PXIe-6341 hooked up with a SCB-68A).
Manual of HIH-4000 can be found here http://www.farnell.com/datasheets/1685535.pdf
First I enabled the Single-Ended sensor reading on SCB-68A by turning on switch 1 at S1.
And I hooked up -Ve to AI GND (67) and data to AI 0+(68), and +Ve to a external HP Power source of +5V. And I connected a 100kohm resistor between -Ve and Data as required on the manual.
I started with checking the Test Panel in NI MAX and found that I just received a constant reading using the RSE input configuration though I kept changing the ambient humidity.
I am wondering if I did something wrong with the connection.
Thanks guys.
(3,909 Views)
Hi abright,
I haven't noticed anything apparently wrong with your connection. Have you tried reading the voltage output of the HIH-4000 directly with a digital multimeter?
Tom D.
Staff Software Engineer
NI
(3,882 Views)
