Multifunction DAQ
No DAQ Device listed in Labview 2010 Linux
I have a problem with DAQmx Base 3.4.0 under Linux:
mxbaseconfig shows my device NI-6009 at the USB port. I can also create tasks corresponding to the Ni-6009 in there. When I try to create a task in Labview 2010, the I/O constants are always empty. The pulldown-arrow is greyed out. If I enter the device name directly in the constant, it throughs me an error 😞 Semms like Labview don't know, which DAQmx Base instruments are connected...
With VISA devices I have not this problem. All VISA devices are shown in the pulldown-menu of the constant and are working correctly.
lsdaq gives me:
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
NI 6220:     "Dev1"    (PXI1::4::INSTR)
NI USB-6009: "Dev2"    (USB0::0x3923::0x717B::0119B3BD::RAW)
I'm using
Redhat Enterprise Linux 5.5
NI-488.2-beta-2.51b1
NI-VISA-5.0.0
NI-DAQmx Base 3.4.0
Labview 2010
All installers worked fine...
Any idea how I get access to my NI-6009?
(4,175 Views)
Hi Felix1234,
maybe there is something wrong with your DAQ-driver-version/-installation. I propose to download the following driver and start with a new installation. Please consider to install all the drivers after the software insallation (Software -> then modules+toolkits -> then drivers).
NI-DAQmx Base 3.4 - SUSE, RedHat:
http://joule.ni.com/nidu/cds/view/p/id/2128/lang/en
The following main features were added in NI-DAQmx Base 3.4
  • LabVIEW 2010 Support—in addition to LabVIEW 2009, LabVIEW 8.6 and LabVIEW 8.5.
  • OS Support—NI-DAQmx Base now supports the following Linux distributions:
    • openSUSE 11.1 and 11.2
    • Red Hat Enterprise Linux WS 4 and 5
    • Scientific Linux 5.4 and 5.5
I hope this helps you!
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(4,143 Views)
Labview was installed before the driver packages.
I looked hat he examples, that come with DAQmx Base. There the device-port-ID is connected by an string variable to the DAQmx Base Vi...works also perfectly for me. But I still don't know, why the I/O variable is noit working...
(4,140 Views)
Accepted by topic author Felix1234
DAQmx Base does not populate the LabVIEW controls like DAQmx does [1]. Since the driver doesn't use any background services, it cannot tell LabVIEW which devices and channels are available on the system.
[1] NI-DAQmx Base Tasks and Physical Channels Are Not Listed in the LabVIEW Task and Channel Constants and Controls
http://digital.ni.com/public.nsf/allkb/57393FEDF313E99B86256F0B0010AD2D
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(4,134 Views)
@NI:
why not just plugging the driver into the IIO infrastructure (as everbody else does) and let LV just ask the kernel for available devices ?
Ah, wait, you're still stuck in the dark ages of the holy inquisition ... 😮
http://forums.ni.com/t5/Multifunction-DAQ/Linux-NIDAQmx-install-problem/m-p/3225670/highlight/false#...
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(3,415 Views)
