09-10-2007 02:30 PM
How do I configure a ni-daqmx device (model USB 2610) to work with LabVIEW 7.0
which has programs that were already running with an older ni-daq device? I get to the point
where I am starting the VI for the data acquisition, and I get a message that the device I have connected
either is not compatible or needs to be configured. I'm positive it is compatible, but I don't know how to configure it
(i'm just a summer intern at the company)
09-11-2007 06:41 AM
Is your Device USB 6210????
If Yes, this device is supported only by DAQmx 8.3 and above versions of Device Drivers
But this Device driver DAQmx 8.3 is only for LabVIEW 7.1 and above.
So your USB 6210 will not work with LabVIEW7.0
The best suggestion would be to upgrade your version of LabVIEW to one that is supported by NI-DAQmx 8.3 or above
09-11-2007 09:12 AM
09-11-2007 09:25 AM
Any program written in version 7 can be opened in version 8. Since you have been unable to get anything to work in v7, I'm not sure what you would want to transfer. The VIs you write should be in a separate folder from LabVIEW and the only settings to be done are in MAX. You might want to make a backup of any VIs you created in 7 because once you open and save them with version 8, you can't go back. You really need to provide more details of what functions you are using and what exactly do you mean by 'unsuccessful'. Error codes that are generated are an essential piece of information.
First, verify that DAQmx is installed on the pc with version 8 and that the device is recognized. There are test panels that can be run. Then you can look at the DAQmx shipping examples or try the DAQ Assistant.
09-12-2007 10:21 AM
09-12-2007 10:28 AM
09-12-2007 12:00 PM
09-12-2007 02:56 PM
