Multifunction DAQ
NewCtrlMenuItem
Using NewCtrlMenuItem, I created a new menu item for a table called "Plot Data." I want to be able to right click on a cell and select "Plot Data" and have it generate a strip chart for the selected cell. How do I use the Event Function parameter of type "CtrlMenuCallbackPtr?" Does this parameter point to the function that I want to execute?
(2,686 Views)
Sir,
I believe that is exactly what you would want to enter here. This of course is assuming that you have generated and filled out the callback function that correlates to the Plot Data menu item. Let me know if that doesn't work for you, so that I can do some testing. Thanks, and have a great day.
Daniel McChane
Application Engineer
(2,686 Views)
