Multifunction DAQ
Need to unreserve a counter in a finite pulse train generation
Hi. Let´s introduce my application first: I´m trying to generate a N-pulse train with the M series PCI-6221, in order to achieve a high frequency clock for an SSI transducer. That´s why i can´t use a software generation (because of the high frequency) and i have to use a finite pulse train. Besides, I would need to use another counter for a variable and finite count (but not simultaneously). The problem is that, as i think i have understood, this finite pulse train involves the two counters working together, so I can´t programm another task with that resources.
My question is, Is there any way to do the finite pulse train generation, unreserve the counters, wait for a finite count to finish and so on?
Thanks.
(2,886 Views)
My knowledges tell me that you need two counter to generate a finite pulse train.
The first counter generates a pulsed of desired width and the second counter generates the pulse train which is gated by the pulse of the first counter (Counter 0=Pulse Generation, Counter 1=Pulse train generation).
However, the finite pulse train generation and the continuous pulse train generation seem similar. The key difference is the generation mode from continuous to finite and the use fo a DAQmx Wait Until Done vi instead of a loop to monitor user input. From a point of view of the hardware there is a difference between the two. Continuous pulse train generation requires only 1 COUNTER.
Maybe you can try with a continuous pulse train generation and with this method you have another counter to do a finite count.
Regards
DiegoM.
(2,873 Views)
