Multifunction DAQ
Need to generate +-5V square/bipolar analog output using 4 channel outputs USB - X series 6353
I am using a USB X -series with 4 analog outputs channels. I am trying to generate 4 square waves from 4 different channels. Please see attached image for detail. I am fairly new with LabView
(4,319 Views)
You could use some of the retrigger options of the DAQmx functions, but there is no short answer here; will suggest that you check the following whitepaper:
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
http://www.ni.com/white-paper/2835/en/
(4,285 Views)
Thank you
(4,279 Views)
