Multifunction DAQ
Need additional trigger inputs on X series
I have an unusual situation where I have a custom hardware board that plugs into one of the two connectors on the PCIe-6323.  Unfortunately, its the connector that has all of the PFI pins, which means that I only have access to AO, AI, DI, and DO pins, and I need to arm a counter off a TTL signal.  Looking at the X-series manual, I can see a few possible workarounds:
1)  Use the AI and the Analog Comparison Event as a trigger source.
2)  Use DI Change Detection to generate an event which is routed to PFI
3)  Hack a cable to one of the RTSI pins on the PCIe board (? not sure if this is possible?)
1 seems straightforward, but I'm worried about timing jitter.  Is 2 a better idea (or even possible)?
(3,125 Views)
Hi saratoga,
I think that option number 2 will be your best bet. I can see two ways to do this:
1) Export your digital input on a PFI line, and then physically use a wire to connect to another PFI line that your arm counter is pointed to.
2) I believe that there is a way to export your digital signal directly to the counter arm on the PCIe-6323. Look into using "Ctr0ArmStartTrigger" as the "output terminal" input of "DAQmx Export Signal". You will have to select "Include Advanced Terminals" in the "I/O Name Filtering..." option when you right click the "output terminal" constant to see this option.
Mark M.
Applications Engineering
(3,093 Views)
Unfortunately I can't access any PFI pins (there are none on block 2 of the 6323), so the problem is how to get the signal into the system.
The workaround I found is to wire to the RTSI pins, which as far as I can tell function just like PFI pins.
(3,082 Views)
