Multifunction DAQ
NIDaqmx Python: Acquire Multichannel Analog input
I am attempting to program a myDAQ device to acquire multichannel analag input  using the nidaqmx library in Python.
I want to receive voltage data in 200kHz sampling rate.
however, when I try to change sampling rate to 200kHz, It does not work.
Here is a test code I have set up:
with nidaqmx.Task() as master_task, nidaqmx.Task() as slave_task:
    master = master_task.ai_channels.add_ai_voltage_chan("Dev1/ai2")
    slave = slave_task.ai_channels.add_ai_voltage_chan("Dev1/ai3")
    slave_task.timing.cfg_samp_clk_timing(200000)
    master_task.timing.cfg_samp_clk_timing(200000)
    print(slave_task.timing.samp_clk_rate)
    print(master_task.timing.samp_clk_rate)
    master_task.stop()
    slave_task.stop()
    master_data = master_task.read()
    slave_data = slave_task.read()
    i = 0
    tic = time.time()
    while True:
        toc = time.time()
        if i==0:
            Result = np.array([[(toc-tic)],[master_data],[slave_data]])
        else:
            Result = np.append(Result, [[(toc-tic)],[master_data],[slave_data]],axis=1)
        if Result[0,i] >= 10:
            break
        else:
            i = i +1
(6,606 Views)
Hi jasonim,
Can you describe in more detail what you mean by "does not work"? Is there a specific error message that you are getting, or what is the behavior?
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(6,557 Views)
I use below code to set up sampling rate to 200kHz
before I add above code to whole code, it works
however when I add this code to set up sampling rate, it does not work
when I executed whole code, python said "it is reserved another work" something like this
(6,546 Views)
Before I added this code, sampling rate was 1000Hz
However, when I try to whole code after adding above code
DaqError is displayed
DaqError: The specified resource is reserved. The operation could not be completed as specified. Task Name: _unnamedTask<5>
(6,518 Views)
Most DAQ devices won't support 2 distinct hw-clocked AI tasks at a time.  They only have 1 "timing engine" available to be shared across whatever AI channels you add to the task.  That's likely the reason for your error.
It appears you could simply put both channels in the same task as you seem to want them to sample at the same rate, and you're trying to start, read, and stop them at the same time.
I can't promise this is the *only* problem with the code -- I only program LabVIEW so I don't really know the text syntax or API.   I *will* mention that it's odd to configure your task(s), then immediately *stop* them (you haven't started them!), and then try to read from them.   It would be much more normal if those stop calls were starts instead.
-Kevin P
(6,504 Views)
