Multifunction DAQ
NIDAQmx : scanning more channels for a real time application in cpp
Hi everybody, sorry in advance if I will appear a bit trivial and dummy... I am asked     1) to scan more - at the moment just 2 - channels from the DAQ "NI USB-6251", and     2) elaborate them in a certain way. The 2nd point has been obviously done, but the 1st - which should be supposed to be easier and well known - is actually giving me more problems. What I exactly have to do is acquire Analogic Voltage Signals (2 channels) in a buffer (long enough to let the 2nd step finish) and copy it in a somewhere variable to use it in the 2nd step. Nothing more. I am using the NIDAQmx.lib. For example I want to aquire these 2 signals with a Fc=10 Hz in a window of 1s (10 samples for each signals - then 20 samples), many many times, and every window I want to have these values in a variable which will be elaborated somehow (my 2nd step...)... What changes should I need? Thank in advance!!!  Pgallir
(3,460 Views)
Hi pgallir,
I've made some changes at your code to fit your needs.
  • I've changed the buffer dimensions and the data array dimension to get 10 samples per channel.
  • To acquire and analize the data every seconds you need to use a continuous acquisition, so "DAQmx_Val_ContSamps" in the  "DAQmxCfgSampClkTiming" function.
  • Besides that, you have to put the "DAQmxReadAnalogF64" in a while loop, to read continuously, and set an exit condition from the loop. In the example I'm attaching I just decided to acquire for 10 seconds. The exit condition is up to you.
  • As a post processing analysis I've calcualted the mean of the two channels acquired.
I'm attaching the example that should help you solving your problems.
Andrea N.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(3,438 Views)
Grazie mille!!!
I will let you know if I will be in trouble again or not... 😄
Pgallir
(3,419 Views)
mmm.... just a question.
suppose to have an heavier processing analysis, how does it work on line?
I mean, read_task is a line command of the loop, then I don't read them simultaneously, do I?
Thank you again.
Pgallir
(3,369 Views)
...on the other hand, I got the _possible_ solution, since it does exist a function which let the DAQ acquire while at a certain point calls another function - which might be written by our own to post process the acquired datas...
I write what I supposed in the following to have a feedback and see if I am right or not....
int main()
    while(1)
                if(_kbhit()){break;} // to stop the task when I want and go on...
                DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Acquired_Into_Buffer,1000,0,EveryNCallback,NULL);
int32 CVICALLBACK EveryNCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData)
    int32       error=0;
    char        errBuff[2048]={'\0'};
    static int  totalRead=0;
    int32       read=0;
    float64     data[1000];
    // DAQmx Read Code
    DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,1000,10.0,DAQmx_Val_GroupByScanNumber,data,1000,&read,NULL));
    if( read>0 ) {
        printf("Acquired %d samples. Total %d\r",read,totalRead+=read);
        fflush(stdout);
// HERE I THINK I SHOULD DO MY ELABORATIONS WITH THE ACQUIRED DATAS
Error:
    if( DAQmxFailed(error) ) {
        DAQmxGetExtendedErrorInfo(errBuff,2048);
        // DAQmx Stop Code
        DAQmxStopTask(taskHandle);
        DAQmxClearTask(taskHandle);
        printf("DAQmx Error: %s\n",errBuff);
    return 0;
However, I have tried with the example "ContAcq-IntClk.c" , but it doesn't work because the compiler seems not to find these two functions - both of which should be declared in "NIDAQmx.h" and defined in "NIDAQmx.lib", isn't it?
1>------ Build started: Project: VC_ContAcqSamps_IntClk, Configuration: Debug Win32 ------
1>Compiling...
1>main.cpp
1>c:\documents and settings\admin\desktop\ppp\main.cpp(65) : error C3861: 'DAQmxRegisterEveryNSamplesEvent': identifier not found
1>c:\documents and settings\admin\desktop\ppp\main.cpp(66) : error C3861: 'DAQmxRegisterDoneEvent': identifier not found
1>Creating browse information file...
1>Microsoft Browse Information Maintenance Utility Version 9.00.21022
1>Copyright (C) Microsoft Corporation. All rights reserved.
What do I do, now?  I have totally lost  the way...
Just to summerize whereas I didn't fit my problem:
I have 2 channels to acquire and make something with these signals ( like 2 filters, give them to a Neuro-Fuzzy kernel, take the output and send it to  serial data), contineusly. I am using NI USB 6251  -  which should mean to use only "NIDAQmx.h", am I right? .
THanks in advance to anybody will help me.
(3,360 Views)
I forgot to post the code which gave me the errors... sorry...
Pgallir
(3,359 Views)
