在 04-18-2006 04:35 AM
That DLL is installed to the Windows\System32 directory when NI-DAQmx Base is installed. Since the USB-9008 is supported in NI-DAQmx. I would recommend to use the DAQmx API to program your device.
I want to access my USB from Java, for that I must have .dll instead of .lib libraries, it is enough to import functions from nidaqmxbase.dll or I need to import functions from other of the .dll listed in Windows\Sysem32??
best regards
Gerardo
