Multifunction DAQ
NIDAQ
I'm trying to install the NI DAQmx, and compile .h and .lib files. The problem is that the 64 bit folders with this specific files aren't available there. When I try to run the mex compile this shows errors related to the architeture of the PC. I have a 64 bits pc, but when installing the NI drivers only the x86bits shows up.
(596 Views)
I am not sure what you are trying to do with mex compile.
If you are using MATLAB, use Data Acquisition Toolbox
If you are using C programming, the 64-bit library is available at C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64
https://tmesystems.net/
(568 Views)
