Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
01-03-2024 04:44 PM
Hey there,
I have been using a NI9219 for some high resolution voltage measurements in labview.
I happen to need to look at data sensor from a sensor with 4-20 mA output. Since the 9219 is current input capabilities I was hoping to use it, however for some reason when the sensor is wired up to the 9219, the differential voltages I am reading on the other 2 channels are reading absurd values.
I am following the wiring instructions provided here:
https://www.ni.com/docs/en-US/bundle/ni-9219-getting-started/page/overview.html
in labview I have a task reading the first 3 inputs (first one is the current input and the second and third are voltage input)
am I missing something? do I need to run different tasks? or is the unit not able to combine current and voltage inputs?
thank you
01-03-2024 05:16 PM
You can mix voltage and current channels in the same DAQmx task.
Here is the article - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAmzSAG&l=en-US
01-03-2024 05:35 PM
thank you - so 2 tasks are needed.
But the fact I am using just one, does that explain why, the values reported by the read function are wrong?
01-03-2024 06:24 PM
same issue with the layout proposed by the link you sent:
the voltages readings out of range as soon the current input is connected.
same behavior as I had with the project level task setup, in which I had the internal resistor selected.
I realized that I don't have the internal resistor set up right now, so I will try that next.
01-03-2024 06:41 PM
same result with the internal resistor selected. I will try external resistor next I suppose. It does feel like a hardware problem to me.
