Multifunction DAQ
NI USB-6501Hardware starting Question
Hi all
I have the question relative to USB-6501 hardware configuratio.n
When i plug-in the NI USB-6501 port each time, the DAQ will be Maximum for all Input first.
How to avoid this setting. I would like to set all low for all input firsy. Is it possible??
Best Regards
Steve So
(2,952 Views)
In the product manual of the card, page 6, 8 and 9 : there is pull-up resistance (4.7 kOhm) to set the DIO on the high impedance. And they don't say if there is a way to change it ... Maybe you can try to connect an other resistance to gnd to force the DIO down.
Wilfried.
(2,941 Views)
Hi Steve,
Your board does not support programmable power-on states between your computer's startup and NI software execution. Some possible solutions can be found in this post. Please post back if you have any further questions. I hope you find this information useful.
JaceD
Signal Sources Product Support Engineer
(2,936 Views)
