Sir,
I have only recently started working on the NI USB-6008 for my university project on temperature control of a plastic extrusion machine using adaptive fuzzy inference-based gain tuning PID controller. The controller implemented on the PID and Fuzzy Toolkit of LabVIEW works well on simulation. Now, I am testing it on actual hardware.
As an initial test, I am trying to control the temperature of water boiling in an electric kettle.
I am using a J-type thermocouple to measure the temperature of water. The results are attached herewith, with the amplitude representing the conditioned voltage in volts. The calibration is 10 mV for every degree Celsius temperature. As evident from the figures, the result I get is noisy, most probably due to vibration of water in the kettle while boiling it. I have attached the vi, in which I have only used an express VI acquiring the voltage and logging it into a spreadsheet file. I am not sure what kind of signal conditioning to do to get rid of this noise: filtering or moving average or anything else.
I tried filtering using a LPF, but it gives an error saying 0<low_freq<high_freq<(sampling freq/2). As far as I know, I kept the low freq to 100, high freq is default to 400 and sampling freq is 10KHz, I believe (USB 6008). What mistake am I making if filtering is required.
Otherwise, what other signal conditioning should I perform? Would it be advisable to perform the signal conditioning before data acquisition in hardware blocks or using LabVIEW itself after data acquisition?
在 03-13-2011 11:22 AM
Good morning:
You basically need some hardware signal conditioning to bring the signal level up to the input range of the 6008. With the low signal voltages and high source impedance of the thermocouple, you will likely see interchannel noise from switching settling times, plus induced noise in your thermocuple leads.
I would recommend using something like the 5B series signal conditiioners. They should be available on the NI web site. They will bring the signal levels up to the 0-5 or 10 volt range, and the source impedances down.
Hope this helps,
Good luck
Dave
ve3eoq@shaw.ca
