Multifunction DAQ
NI-SCOPE error -223409
I've had an error in the NI-SCOPE driver (version 4.1.3), using the NI-5122 digitizer. The error occurrs in the niScope_SendSoftwareTriggerEdge function. The relevant sequence of commands I'm sending is:
iStatus = niScope_Abort(SessionID);
iStatus = niScope_ConfigureHorizontalTiming(SessionID, 380E6, 256, 0.0, 1, VI_FALSE);
iStatus = niScope_ConfigureTriggerEdge(SessionID, "0", 0.0, NISCOPE_VAL_POSITIVE, NISCOPE_VAL_DC, 0.0, 0.0);
iStatus = niScope_ConfigureChanCharacteristics(SessionID, "0", NISCOPE_VAL_50_OHMS, 0.0);
iStatus = niScope_ConfigureVertical(SessionID, "0", 0.2, 0.0, NISCOPE_VAL_DC, 1.0, VI_TRUE);
iStatus = niScope_InitiateAcquisition(SessionID);
iStatus = niScope_SendSoftwareTriggerEdge(SessionID, NISCOPE_VAL_SOFTWARE_TRIGGER_REFERENCE);       // iStatus = -223409
The return from niScope_errorHandler is:
Error FFFC974F.
Possible Reasons:
Internal Software Error occurred in Scopes software. Please contact National Instruments Support.
Component Name: nihsdrk
File Name: \Measurements\highSpeedDigitizers\hsd\driver\trunk\4.1.1\source\kernelPrimitive\tMacroSupervisor.cpp
Line Number: 716
Source:
    unknown (0): ???
    unknown (0): ???
    unknown (0): ???
    unknown (0): ???
    unknown (0): ???
    unknown (0): ???
    unknown (0): ???
    unknown (0): ???
    unknown (0): ???
    unknown (0): ???
Status Code: -223409
The error does not occur if I call niScope_close and niScope_init after every acquisition, but I assume I shouldn't have to do this.
(4,271 Views)
Accepted by topic author Tevildo
Hi Tevildo,
This is a known issue, you're right that you shouldn't have to call niScope_close and niScope_init after every acquisition, but for the time being that's the best workaround.
Al C
National Instruments,
Application Engineer
(4,220 Views)
Thanks for the info.  What I've actually done is to get rid of the SendSoftwareTrigger call and put the instrument to free-run acquisition for the initial measurement, then change back to triggered for the rest of the measurements.  But I'm glad to know that this is a known issue.
(4,212 Views)
