Multifunction DAQ
NI SCB-68A "A GND" and "D GND"
the NI SCB-68A connector has several Analog Ground "A GND" and "D GND".
All Analog Grund are not connected to other Analog Ground, means when i try
to measure from one AGND to another AGND.
Does that mean that i must connect ALL AGND to my source ground or only one?
If so all AGND must connected to each other on my PCI-6225 internally. Is that the case?
Do i need to connect all digital grund or just one?
(5,427 Views)
The PXI-6225 is tricky as the two Connectors "0" and "1" have very different ground assigments, but the SCB-68A connector block attached to either appears the same.  Furthermore, the SCB-68A schematic on the inside of the cover is only for Connector "0" and only if you have cabled with the SHC68-68-EPM cable.  Lastly, the SCB-68A has circuitry selectable via on-board switches.  So, please describe exactly which 68-pin connector ("0" or "1") on the PXI-6225, and which cable  ("EPM" or other), and the position of the switches.
(5,411 Views)
The grounds are connected inside of the DAQ card.  Therefore, you do not want the grounds connected in the terminal block.
GCentral
(5,408 Views)
