Multifunction DAQ
NI PCI 6251 Error in Continuous and Finite Mode
I'm using NI PCI 6251. Recently, It appears error like this: I acquire signal by Test pannels in MAX, If I select "MODE": On Demand, it's running ok. If I select "Finite" or "Continuous " mode, Start acquire signal is ok but when click Stop button, the MAX is hang on. If I close the Test pannels and re-open it again, error  89123 appear. I reinstalled the Driver, however this time the error 50103 appear, something relate to NI platform service.
Could anyone can solve this problem?
(4,516 Views)
What version of the DAQmx driver are you using?  Are you able to self-sest the device in MAX?  If so, what are the self-test results?
Are there any other programs trying to access the device while you are using the MAX Test Panel?  Error 50103 is typically related to several applications attempting to reserve device resources simultaneously.  You can find more information about it here: http://digital.ni.com/public.nsf/allkb/485201B647950BF886257537006CEB89?OpenDocument.
Cody A.
(4,476 Views)
