Multifunction DAQ
NI-DAQmx
Good Afternoon,
I am trying to install the NIDAQ910f0.exe and I still have the same error message that I don't have access to the  niRemoteDD.dll located in NI\MAX\Data Dictionnaries. What can I do to install this program properly?
Thank you
(3,167 Views)
Hi Noushka,
Are you running your installation as an Administrator?  If you are you may want to consider redownloading the file to ensure that it is not corrupt.
Dustin D
(3,130 Views)
Hi Dustin,
Yes I am running the installation as an Administrator and I used the file that I downloaded yesterday, but I will try again.
Thank you
Nanouska
(3,124 Views)
