02-27-2013 06:06 PM
I recently upgraded to a new version of the NI-DAQmx drivers (9.6.1 and then 9.7.0) from a much earlier version (9.4.0). After the upgrade, the computer hangs on the "Please Wait" screen as it is starting windows for about 20 minutes. This is before I can entry the user name and password. Removing all the NI software on the machine fixes the problem. I am running windows 7-64 bit and am joined to a network.
Any ideas?
Tom
03-05-2013 07:03 AM
Same thing here. Seems updating the MAX from 5.1 to either 5.3.1, 5.3.3, 5.4 causes this problem.
We have this on 4 Lenovo laptops and a Panasonic laptop.
But: This only occurs when the computer is not connected to LAN or connected via WLAN. When a network cable is connected boot times are normal.
03-06-2013 11:08 AM
Are there any firewalls or antivirus software on your computer that could be causing problems? Also, did anything else change on your computer other than upgrading DAQmx?
03-06-2013 01:18 PM
No changes to the rest of the computer. I did find the solution that the LABView guys are using and it worked for me as well:
- Disable the NI mDNS Responder Service through services.msc
- Modify the following registry key (Change Enabled to 0)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\WinSock2\Parameters\NameSpace_Catalog5\Catalog_Entries\000000000005
- Note: Do not just pick 000000000005, click on each catalog entry until you find the one whose
DisplayString is mdnsNSP and set that one's Enabled to 0.
For 64-bit Windows, you may have an additional key under Catalog_Entries64 which should also be set to 0.
Tom
03-28-2013 11:18 AM - edited 03-28-2013 11:19 AM
I agree with PhysicsGuy.
Had the problem on 3 computer. Updated DAQmx from 9.5.2 to 9.6.2 and boot up time was around 15 minutes.
After following the instructions from PhysicsGuy everything is fine and windows 7 x64 boot time is normal.
