Multifunction DAQ
NI BNC-2120 (6229), VGA BNC cable 15 pin or 15HDpin connection?
 we have a NI BNC-2120 (6229) and want to connect a new pressure gauge, which conncetor is a female 15 HD pin. all the others we have got connected are 15 pin only (so just two rows), so I was wondering if we would face compatibility problems ?
thanks
(3,096 Views)
Hi Chiara90,
When you say 15 HD pin, which connector and cable are you wanting to connect to and use?
Best Regards,
James Kinch
(3,057 Views)
Hi!
thanks for replying.
I would like to connect it to a BNC cable (with a 15 pin male connector suitable to connect to the gauge on the other side).
 I have attached the png file of the pins in the gauge connection.
(3,055 Views)
Accepted by topic author Chiara90
Hi Chiara90,
You should be able to find adapters that convert VGA HD 15pins to BNC. These are readily available online I believe.
Best Regards,
James Kinch
(3,037 Views)
Oh thank you very much.
(3,035 Views)
