Multifunction DAQ
NI-9775 Chassis Inquiry
Howdy,
I am currently using the Hi-Speed USB Carrier Chassis for my NI-9775; however, I am getting a "No Cartridge Found" Error. I am assuming this is because the cartridge is not compatible with the NI-9775. Could someone tell me what the compatible cartridge is for this device?
Thanks in advance!
(1,074 Views)
What chassis model do you have? can you please post the screenshot of the error you experienced?
NI 9775 is supported by DAQmx, this means cDAQ chassis should support,
Santhosh
Soliton Technologies
(1,065 Views)
I am planning to purchase NI 9775 with NI cDAQ9171. are they compatible or will they work together?
(439 Views)
Yes, they are compatible but may be performance-limited as responded in this post - https://forums.ni.com/t5/LabVIEW/Examples-using-NI-9775-with-cDAQ-chassis/m-p/4461054#M1317707
Santhosh
(422 Views)
