Multifunction DAQ
NI 9402 as trigger for NI 9239 in LabView using DAQmx
I would like to know if it is possible to Use the NI 9402 Module to receive a TTL Trigger Signal from a Wave-Generator to trigger the measurement with a NI 9239 Module in LabView.
When I try, it always says, that there is only one channel type allowed in one task.
Manuel
(4,001 Views)
I just did it. It works. Unfortunately the start of the trigger is moving. Very slowly the analog curve moves. I recognised this before when I used the NI 9205 Module to tigger the 9239 Module. It also works, but the trigger is moving a bit. If I only use the 9205 Module the trigger is constant. Whenever there is a second Module in the LabView Program, where one is triggering and the other is measuring, The start of the measurement is moving very slowly.
Best regards
Manuel
(3,994 Views)
