08-09-2025 03:52 AM - edited 08-09-2025 04:00 AM
Hi all,
I am setting up load cells with NI 9327 with MATLAB. I used 4 load sensors which using all slots/channels.
08-09-2025 08:08 AM
The error states that the channels in a task must have the same excitation voltage.
Please try creating separate tasks for each channel that has a different excitation voltage.
08-10-2025 12:45 AM
Yes, it has to be same voltage per channel, the question is does all accumulative voltage need to <10V ?
08-11-2025 08:43 AM
No, it is not sum of all excitation voltages. The excitation voltage is specified per channel and not total across all channels.
