Multifunction DAQ
NI 9265 module
I have an NI 9265 module. It will output a current when using MAX but it will not work with the DAQ express vi.
The error is saying
Measurements: Not enough samples were written to satisfy the initial data transfer request condition
(3,059 Views)
Hi
Is it possible for you to post your code? How many samples are you outputting and at what rate? Changing the buffer size should fix the issue. Post your code so we can provide some suggestions to you.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,044 Views)
