Multifunction DAQ
NI 9263 connector
I have NI 9263, 4 channel analog output module. I want to output signal from LabVIEW to a signal processing device that has female BNC. Which connector will be best for this. NI 9263 has screw terminal that has to be connected to the femal BNC terminal
(3,803 Views)
Hello Stame,
I would take a look at some bare wire to BNC Male adaptors such as on this page which would allow you to connect your 9263 to the BNC Female end of your signal processing device.
Izzy O.
ni.com/support
(3,782 Views)
Hello!
On the website for C-Rio Drivers, under supported hardware, is listed the "NI 9263 BNC".
http://www.ni.com/download/ni-rio-14.0.1/4862/en/
Is there a 9263 module available, that has the BNC connectors already built in? I can't find anything about that.
Thanks!
(3,363 Views)
