Multifunction DAQ
NI 9222 sampling rate
The NI‑9222 can sample at the maximum sample rate per channel while the module next to it samples at a much slower rate, which is ideal for mixed-measurement test systems.
I found this in the website. Does this mean that if we connect multiple NI 9222 modules to a cDAQ with multiple slots, the sampling rate will be less for the second one and so on?
(1,799 Views)
I believe all NI 9222's will be able to sample at whatever rate it's set to. I think the statement is referring to a module next to it that has a slower sample rate.
(1,786 Views)
Fine. Thank you.
(1,752 Views)
