Multifunction DAQ
NI 9219 to measure temperature using thermistor in 4-wire mode
I am measuring temperature with thermistor sensor using NI 9219 AI module on a cDAQ 9178 chassis. There is no issue when measurement is done using 2-wire mode and displayed result is in complete agreement with calibration report provided by Thermistor manufacturer. However we want to take measurement over a long distance. To get accurate result, we used 4-wire resistance measurement scheme. But the displayed result shows Zero resitance (short). The connections are proper and checked multiple times. I am not able to figure out the error. Whether NI 9219 cannot measure Thermistor resistance in 4-wire mode.
At 25 deg C, Rthermistor = 10k.
Need help.
(4,703 Views)
Accepted by topic author arihant
Hi, what do you mean by "long distance"? What type of wires do you use?
Does the connection look like this?
Also - the program you sent is configured to use 2-wire, not 4-wire method.
(4,671 Views)
My bad.
I switched the Pin 4 connection with Pin 6. I will try after rectifying it.
Thanks for your nice connection visual.
(4,653 Views)
@arihant
were you able to get this working? What is the accuracy you are getting?
Bhavin
(3,827 Views)
Sorry as I could not reply.
Yes, I was able yo do it.
(3,346 Views)
Please mark the appropriate reply as Solution if already solved.
Santhosh
Soliton Technologies
(3,328 Views)
