Multifunction DAQ
NI 9205 with signal conditioner
I have a 9205 connected to a model 126 signal conditioner and endevco full bridge accelerometers. The 9205 lowest range is +/-200 mV. The accelerometers are 400 mV full scale range but I will never need the full scale. I can't seem to get a reading from the accelerometers (no gain applied). I have tried two different accels to rule out the error on the sensor. I connected a 9 V battery and properly got reading with a correct voltage range. I noticed when I went down to a +/- 200 mV range I got a 0.215 mV reading which I also have gotten with my accelerometer connected at that same range so that makes me think that is some kind of out of range error reading. It seems I am not getting a reading in the range with the accelerometer. I had talked with NI before getting this DAQ so I think it should be able to work with this setup.
Message 1 of 1
(1,482 Views)
