Multifunction DAQ
NI 9202, Analog Input with Matlab
I'm having difficulty using the NI 9202 card for analog inputs with Matlab. When I try and add the analog input channel, I get the below error. I saw errors where some NI cards are not supported with Matlab, is this one of them? Is there a work around to get it to work?
I'm using Matlab 2017b.
Error using daq.ni.ChannelGroupStateNoTask/getUnreservedTaskHandle (line 26)
NI Error -200077:
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: DAQmx_AI_Coupling
Requested Value: 97
Possible Values: DAQmx_Val_DC
Channel Name: cDAQ1Mod2/ai0
(3,053 Views)
Hello watersnake,
As you can see NI-DAQmx Support from Data Acquisition Toolbox list NI 9202 is not supported.
__________________________________________
The best way to thank, is to give KUDOS
(2,416 Views)
