Multifunction DAQ
N samples N channels measurement problem.
Hello!
I´m trying to adquire signal from two channels. Just for testing i applied 1V to channel one and 0 V to channel 2.
When i measure them individualy, with the Cont Acq&Graph example i have no problems, but when i read using the Nchan N samples vi i get 1v and 0,3V
What can i be doing wrong?
My code is the following:
Thank you!
(4,369 Views)
Time to have a look at the SPEC of your (probably multiplexing) DAQ device. Look for the settle time error.
Greetings from Germany
Henrik
LV since v3.1
(4,316 Views)
Hi JRRiquelme
I first recomend to test your hardware on NI MAX so we can discard a hardware problem.
Here are two links that may help you
http://www.ni.com/getting-started/set-up-hardware/esa/
http://www.ni.com/academic/students/learn-daq/hardware/esa/
If you have another question or if the problem isn't solved, write me.
Brenda
(4,118 Views)
