Multifunction DAQ
MyDAQ gain and offset errors
 Dear Sirs,
MyDAQ Specifications pdf shows only Absolute Accuracy of the Analog Input 0 and Analog Input 1.
Where can I get gain and offset errors for these inputs?
Thank you.
(1,458 Views)
I believe the MyDAQ is not a top of the line professional instrument which requires such high detailed specs and NI chose to go ahead with absolute accuracy that is valid for the full range.
Santhosh
Soliton Technologies
(1,410 Views)
