07-10-2006 08:47 AM
07-11-2006
12:28 PM
- last edited on
06-28-2024
08:17 AM
by
Content Cleaner
Licenio,
Thanks for posting to the NI forums. I took a look at the pictures you included and have a few additional questions about your setup. I noticed that you had the analog input terminal configuration set to NRSE when measuring from the power supply. Where did you connect the ground from the power supply? It should be connected to AI SENSE to get a proper reading.
For more information about wiring different types of sources to a DAQ device see:
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
Hopefully this gets you started toward a resolution. If need further clarification or if the change in wiring does not fix the problem feel free to post back to this thread.
Good luck.
Neil Stoddard
