Multifunction DAQ
Multiple triggers for one AI
Hi!
I´m reading an analog signal triggered by a TTL signal.
Now i will have 3 different TTL signals and I would like the adquisition to start when the first positive signal arrives.
Is this possible?
Thank you for your help!
(5,060 Views)
What DAQ device are you using?
You can only configure a start trigger to use a single terminal.  However, depending on the device you could configure a digital input task with change detection timing which will generate a pulse in hardware ("Change Detection Event") when any of the three lines transition from low to high--you could use this pulse as your start trigger.
If you don't have a device that supports DI change detection, I would just OR the three signals together with external hardware and use the result as the trigger signal.
Best Regards,
John Passiak
(5,056 Views)
Depending on your signal sources and the slope.... I would make a wired OR with some diodes (1N4148) and a pull down resistor, just like John proposed.
Greetings from Germany
Henrik
LV since v3.1
(5,038 Views)
