Multifunction DAQ
Multiple outputs from DAQs
Using LabVIEW to do a basic Voltage and temperature measurements and tryin to plot them on a graph, can plot one seperately but when i try to plot the second on the same graph labview automatically links the two data lines, i do not want this to happen, i want to display two seperate output lines on the same graph/waveform one for Voltage the other for temperature
regards tom
(2,909 Views)
Build a 2D array of the two voltage arrays/waveforms  and display it on the graph as shown in the attached VI
(2,907 Views)
