Multifunction DAQ
Multiple channel DAQ (using delphi)
I am using Delphi and a NI data-acquisition card (DAQcard-6062E) to acquire data from 8 different channels.
I have been able to retrieve data from one channel but when trying to add more channels I run into difficulties.
The idea is to collect data with one AnalogInput which has multiple channels.
Is it possible to add more channels in the CWAI-control properties window, and if so how does one go about this?
Thx.
Adrian
(3,387 Views)
Officially National Instruments does not support Delphi as a development enviroment. But maybe I can help you a little bit on this control. You should be able to use the following syntax for the channel string either in the properties dialog window of this control or in the function itself:
  • For selecting a span of channels use: x:y with x the first channel and y the last channel in the span.
  • If you want to read some random chanels use comma's to seperate the channels for example: 0,3,6
Hope this helps.
RikP
Rik Prins, CLA, CLED
Software Development Engineer
(3,374 Views)
Thanks for the help.
A bigger problem for me is actually getting the data from a certain channel into a graph/table.
At the moment I've got:
Chart1.Series[0].Add(MyMeasurement, MyTime);
Where "MyMeasurement"  needs to be replaced by the data coming in from the channel.
Do you understand what I'm trying to do and have you got any ideas?
Thanks again.
Adrian.
(3,369 Views)
