Multifunction DAQ
Multiple Analog Triggers
I need to monitor various voltages for over-voltage condition, with an (immediate) hardware output for disabling external equipment.
I know I can set up an Analog Output Trigger on an Analog Input and use this, but can I set up different trigger levels on various channels ?
Effectively use the DAQ AI channels as programmable comparators...
(2,931 Views)
Greetings,
Unfortunately, an analog input trigger can only be configured for one channel at any given time. You may want to consider using DAQ Occurrences. Below, I have included a link to a document that provides an overview of DAQ Occurrences:
An Overview of DAQ Events and Occurrences
You would, most likely, want to use DAQ Occurrence 3. Below, I have included a link to an example program demonstrating how to use this particular occurrence:
Analog Trigger Event Messaging in LabVIEW (DAQ Occur
rence 3)
Finally, I have attached a quick example that uses DAQ Occurrence 3 to monitor two channels. Using this programming structure, you should be able to monitor as many analog input channels as you want.
Good luck with your application.
Spencer S.
(2,931 Views)
Thank-you Spencer S.
I have previously looked at this option, and as long as the time between the "Occurrence" happening and the software responding to it (such as setting a DO) is small it would work OK (small being <100uS).
I had looked at using the GOEPEL PXI 3240 Comparator to do the signal monitoring, but I am very keen to put the DAQ parts of my application on an RT PXI module. If your solution works I can do it !
I would presume that linking a DO to an Analog Input occurrence on an RT module is fast, Is there any way to quantify it - assuming the "Occurrence" thread has highest priority ?
Regards
Ray Farmer
(2,931 Views)
Do not understand how "Ray Farmer" posted my reply ! It is from Clive really...
Regards
Ray Farmer
(2,931 Views)
