Multifunction DAQ
Multiple Analog Input Channels
Hello
1. I have NI-PCI 6259 Card
2. VC++ 6.0 only
3. I use "C" function from NI-DAQmx library
How I can measure Two Analog Input Chanels in the same time? I have set Two Task or One Task for 2 channels ?
(3,523 Views)
Greetings,
To acquire multipel analog input channels, you setup 1 task. You cannot setup multiple tasks of the same type at the same time.
In the follwing funciton:
int32 DAQmxCreateAIVoltageChan (TaskHandle taskHandle, const char physicalChannel[], const char nameToAssignToChannel[], int32 terminalConfig, float64 minVal, float64 maxVal, int32 units, const char customScaleName[]);
If you want to setup more than 1 channel, you can setup a list of channels that you wish to acquire in the "const char physicalChannel[]" input.
To specify a range of physical channels, use a colon between two channel numbers or two physical channel names:
Dev0/ai0:4
Dev0/ai0:Dev0/ai4
Use commas to separate physical channel names and ranges in a list as follows:
Dev0/ai0, Dev1/ai0:3, Dev1/ai6
Dev0/port0, Dev0/port1/line0:2
Hope this helps,
Anuj D.
(3,513 Views)
Hello
OK thanks.I try it.
(3,511 Views)
