Multifunction DAQ
Multichannel synchronization
I want to output a single pulse (analog output) out of aPCI-6052E and read simultaneously 2 voltages of different range from 2 analog input that are (for the moment) connected to the analog output... I inspire myself from the discussion forum on the topic such as the one finded here: http://forums.ni.com/ni/board/message?board.id=170&message.id=257898&requireLogin=False but it seems that there is an hidden mistake somewhere in my very simple VI because I still have problem to write a correct waveform and synchronize the acquisition.
Maybe, have you a hint for me
Thank you again for your help
(3,171 Views)
Hi fr123,
please have a look at the following forum thread that discusses the issue: synchronize 3 analog outputs and 4 analog inputs. At the bottom you'll also find an example for the desired implementation.
Bernd
(3,142 Views)
