Multifunction DAQ
Multi-device task not starting with TSN and impossible to understand is TSN is working
we have 3 cDAQ-9189 connected with a cisco router with TSN support enabled and through a media converter. From the Cisco TSN interface we see TSN packets flowing, so we only *suppose* that they are correctly syncronized.
BUT, the multi device task does not start when we run the task:
Error -201483 occurred at DAQ Assistant
Possible Reason(s):
The selected master for the configured multi-device task is not able to export signals. Make sure that the first channel in the task is from a device on a chassis that has an NI 9469 capable of exporting signals to the slave devices. If you have any delta-sigma modules in your task, at least one must be in the master chassis. For time-based synchronization, ensure all the chassis in the task are in the same synchronization network.
How can we debug the TSN network for:
  1. know if TSN is actually working?
  2. know who is the gran master?
  3. understand why the multi device task is not starting?
Thank you in advance.
(1,181 Views)
Hi maxs29,
found sequence of steps how to solve this issue.
To correct this error, simply ensure any analog input step only includes channels from modules in a single chassis. After configuring the hardware in NI MAX, do the following:
  1. Click Add Step in the top left corner of the SignalExpress window.
  2. Expand Acquire Signals.
  3. Expand DAQmx Acquire.
  4. Expand Analog Input.
  5. Select a measurement type.
  6. Add channels to task, making sure only modules from a single chassis are included.
  7. Repeat steps 1 - 6 for every chassis that needs to be added to the SignalExpress project.
Find more information in these two articles,
Error -201484 When Synchronizing Multiple cDAQ Chassis With 9469 - NI
Why do I get Error -201483 in SignalExpress When Not Using an NI 9469 Module? - NI
Regards)
(1,100 Views)
