Multifunction DAQ
Memory access violation on call to CreateVoltageChannel with .NET 4.0 Framwork
We are using NI4472 and NI4474 Data Aquisition cards using the Measurement Studio 8 assemblies (E.g. NationalInstruments.DAQmx 8.0.11.12).
These have worked perfectly with applications under the .NET 2.0 & 3.5 Frameworks. But when we recently updated to .NET 4.0 we are now experiencing Memory Access Violation exceptions on the first call to CreateVoltageChannel
 using NationalInstruments.DAQmx;
public class DAQmxTask1 : Task
  public DAQmxTask1(string deviceName, string channel, double min, double max, double rate, SampleQuantityMode mode, int samples) : base("EMDetector1")
    this.AIChannels.CreateVoltageChannel(deviceName + "/" + channel, "Voltage", AITerminalConfiguration.Pseudodifferential, min, max, AIVoltageUnits.Volts);
    this.Timing.ConfigureSampleClock("", rate, SampleClockActiveEdge.Rising, mode, samples);
    this.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger("PFI0", DigitalEdgeStartTriggerEdge.Rising);
Does anyone know what the problem is ?
Message 1 of 1
(3,514 Views)
