Multifunction DAQ
Measuring temperature with RTD sensor
Hi guys,
I am a beginner of Labview.
I am measuring temperature on a surface in my machine, using PT100 RTD sensor,
But I dont know which hardware device I need to use, so I think of two options:
1. Use a device (called "unknown device") to connect with RTD sensor , then connect this unknown device with SCB-68A.
2.  Directly connect RTD sensor with SCB-68A? I read SCB-68A manual, I see some guide to measure temperature. However, I am a beginner,
    so I dont really understand this manual.
Please guide me. Please see the picture I attached.
(2,620 Views)
The SCB-68A is just a breakout box to connect something (like your sensor) ..
Usually it's connected to DAQ (Data AQuisition card) .. which one ?
If you open MAX, you should find your DAQ device ...
Try the Task assistance to create a measurement task for your RTD, it will also provide a wirering schematic 🙂
Next: Have a look at the shipped LabVIEW examples and the shipped and online tutorials.
Greetings from Germany
Henrik
LV since v3.1
(2,591 Views)
