Multifunction DAQ
Measuring Current with the NI DAQ 9189 Module and running into sample clock rate issue
Hi everyone,
I am trying to measure voltage and current with the NI DAQ 9189 module. I have a setup that uses the NI DAQ 9227 for voltage which works but when I try to add current measurement to the program using the 9189 module I get an error that says "Error -201087 occurred" with the possible reasons listed as:
"Task contains physical channels on one or more devices that require you to specify the Sample Clock rate. Use the Sample Clock Timing function/VI to specify a Sample Clock rate. You cannot specify a Sample Clock rate if Mode is set to On Demand."
I am not sure what the problem is but I suspect it has to do with my common sampling clock which I use for both the voltage and the current DAQs.
Does anyone know how to fix this issue? Thanks
(849 Views)
You didn't use any sample clock. The software time is not the hardware DAQmx sample clock.
Go to Search DAQmx Examples and refer to Voltage Input - Continuous Acquisition
https://tmesystems.net/
(821 Views)
