Multifunction DAQ
Max analog input Voltage for NI USB-6251
for some measurements I want to change the input voltage range form +-10V down to +-5V. As I understand the datasheet the USB-6251 is capable of handling max. input voltages of -+11V. Does this change if the input voltage range is changed and will I have to protect the board with an external circuit?
(2,864 Views)
You don't have to protect the board with an external circuit.
André (CLA, CLED)
(2,863 Views)
