Multifunction DAQ
Max Hangs at Splash Screen
I have been using MAX OK for many months with compact filedpoint devices but suddenly it has started to hang at the splash screen. This probably started when I installed the latest NiDAQ mx 9 but I cant be sure. I tried deleting MAX's Data folder as suggested in another thread but it made no difference.
Any suggestions anyone?
Tony
(3,231 Views)
Hi S Monkey!
I would suggest to upgrade your field point driver as well if you dont have the latest version. Sometimes the installation of a new driver changes the dependencies another one has. You can try that and see if it works. Another thing you can try is to repair MAX on the add or remove programs tab in the control panel.
Hope this helps.
Have a great day!
(3,221 Views)
