Multifunction DAQ
Matlab error loading library nicaiu.dll
I am using a DAC PCI 6221, in the past days NIDAQ mx was upgraded and the matlab program I use stop working
I uninstalled all the new drivers and I installed an older version NIDAQ 17.1 (matlab runs perfectly with this version in other computers of my lab) but when I try to run it I got the next error message in Matlab;
There was an error loading the library "c:\windows\system32\nicaiu.dll"
I have checked and the file is in the right path. I have tried to uninstall and install older versions (9.5.5 for example, also used in my lab) and there is always a missing file either nicaiu.dll or sometimes mscvp90.dll
Do you have any clue about what is happening?
Thanks for the help
Thank you
(1,257 Views)
What is your OS version? Is it compatible with the NI-DAQmx version? See NI Hardware and Software Operating System Compatibility
Have you tried Using Test Panels in Measurement & Automation Explorer for Devices Supported by NI-DAQmx?
https://tmesystems.net/
(1,237 Views)
