Multifunction DAQ
MAX export function error
Randy,
I am currently investigating a similar case. Would you be so kind to generate a "Technical Support Protocol" from MAX and post the .zip file here for comparison? You can access this fuction in MAX from the menu File » Create Report... » Technical Support
SFK
Message 11 of 14
(1,566 Views)
I am having the exact same issue on a customer's computer.  Has a solution been found?
Brian
Message 12 of 14
(1,502 Views)
Hi Brian,
We have determined that this is indeed a bug, and have filed CAR ID 142961.  It will likely be fixed in an upcoming version of DAQmx, I would check the readme file for the next version to see if a fix is available.  Just look for the CAR ID in the Fixed Issues section.
In the meantime I am not aware of a workaround other than reverting to a previous version of DAQmx.
-John
John Passiak
Message 13 of 14
(1,482 Views)
Hi Brian,
I apologize, I had misread the bug that R&D had reproduced and fixed--please disregard my previous post.
We have gone through great lengths to try to reproduce the behavior that you are experiencing and have still been unable to do so.  If you have any specific instructions for us we can continue to try to recreate the problem--this would be the first step in looking into a possible fix.
-John
John Passiak
Message 14 of 14
(1,445 Views)
