Multifunction DAQ
MAX does not recognize USB-6501
I have USB-6501 (OEM). I installed NI-DAQmx8.3 ( The computer I worked with has windowXP). But, The MAX does not recognize it.
What should I do?
(3,511 Views)
Are you using it on a laptop?  Some laptops have both powered and non-powered USB ports.  Make sure the port is powered.  Also, can you see it in the Windows Device Manager?  If it's not there, it definitely won't show in MAX.
(3,501 Views)
